Wiring of new aftermarket camera to Nav Head Unit?
Hi and thanks in advance for assistance.
My stock rear camera / passenger underseat module (10371724) has conked out (gray fuzz). So I bought a cheap replacement 12v camera (this one) and *all I want to do is wire the camera feed into the head unit to replace the current one.*
My head unit/nav doesn't have an RCA jack (the camera came with one, but I'd just cut it off if need be). My head unit is (15882766) and I've been searching and came up with *maybe* I can wire into this brown connector?? or connect between the module in the existing harness?? I've even seen a (camera adaptor) that might be right --- but I just want to know the right pin(s) to use.
This is my Navigation Head Unit - with the Brown Connector unplugged:
This is the module thing under my seat:
I would really appreciate any help that can be provided here! THANK YOU!
You may find some of the accessories on the Gmbackupcams website. They have a couple of adapters that should allow you to connect the RCA connector on the aftermarket camera to your head unit.
GM Backup Cams — Accessories
Good luck with your repair.
whitelightnin3006
January 5th, 2012 7:22 AM
