Front Axle Shaft Seals?
Hi :-)
I need to change my front axle shaft seals on my 2000 Suburban 1500 My first question is : are they the same left & right? If so is this part number correct? (sorry about using a vendor site but they have lots of parts info) https://www.rockauto.com/en/parts/ac...haft+seal,2336 Thank you very much for any feedback about this S. |
when you do the job....the left side shaft can be hammered out...the right side can't...the extension housing must be removed.
Hi
Yes I know that I will have to remove the shaft on that side ;-) But are the seals the same on both sides? and is that part I mentioned correct? Thanks for the tip :-) |
