2005 Chevy suburban
Old July 1st, 2009, 1:18 PM
crewcab00's Avatar
Default 2005 Chevy suburban
The rear door will not open. If you hit the unlock on the remote or inside the vehicle, you can hear it unlock and when you push button on door and raise door handle, it will not open. There is no way to get the door panel off because the door is shut. Any suggestions?
Old July 13th, 2009, 5:08 PM
native1223's Avatar
Default my fix
there is a relay switch behind the panel on the pillar between front and back (or middle) seat that is bad it will click if it is good be sure to check unlock and lock for clicking noise its called the b pillar relay
Old January 7th, 2018, 8:29 PM
Adam Bartimmo's Avatar
Default Brake pedal shutters
My brake pedal shutters when I first start the truck but after I press all the way down on the pedal it works fine. Is this due to low brake fluid or air in the brake line?
hsmith22
December 28th, 2013 5:20 PM
EmergencyManagement
December 6th, 2013 9:22 PM
Scott N Vanessa Weaver
December 28th, 2012 3:58 PM
Gratefuld2
July 11th, 2012 2:17 PM
Tashier
May 27th, 2011 12:52 PM
Quick Reply: 2005 Chevy suburban
