2000 tracker 2dr antenna
Putting a new antenna on my tracker. Has anyone seen where the antenna coax cable connects to the radio extension coax cable. I do not see it, the helm shop manual say it is above the
left side wall junction box area. I looked under the left dash with a flashlight, i will remove the panel under the steering wheel, maybe i can see into the corner better. |
200 Tracker 2dr antenna
It is located under drivers side dash above fuse panel block. Hope this helps.
Tracker Antenna Replacement
I am going to remove the panel under the steering wheel, it has 3 screws that hold on, i think you should be able to see back into the corner better to look for the antenna coax. i will get back to it in April, the Tracker is covered up in the garage, it is still cold in Pennsylvania.
| All times are GMT -5. The time now is 5:08 AM. |
