2001 tracker rear drum brakes
does anybody know how to get the rear drums off a 2001 tracker? this is not the first time i've worked on a car and i cannot figure how to remove the drums.
i did the front disks, no problem. |
RE: 2001 tracker rear drum brakes
https://chevroletforum.com/m_14479/tm.htm
Check this link ... apparantely there's two holes in the drum for metric bolts to remove the drums. |
On my 2002 Tracker you have to use 2 8MM bolts and screw them into the 2 holes in the vertical surface of the drum. The bolts push on the axel and force the drum off. I can't remember if the bolts have a fine or course thread, sorry.
Originally Posted by SLJ2137694
(Post 15083)
https://cimg6.ibsrv.net/gimg/chevrol...dafd091703.jpg
The 8 mm bolts have a 1.25 mm thread pitch. https://cimg8.ibsrv.net/gimg/chevrol...5aec84dc1d.jpg The same bolts used to remove the rear drum (shown here) can also be used to remove the front rotor. |
Originally Posted by L84sky
(Post 465235)
The 8 mm bolts have a 1.25 mm thread pitch. https://cimg8.ibsrv.net/gimg/chevrol...5aec84dc1d.jpg The same bolts used to remove the rear drum (shown here) can also be used to remove the front rotor. 1.50 And 1.00 They thread only a few turns each, what other threads can we try? |
https://cimg1.ibsrv.net/gimg/chevrol...ff5390be3e.jpg
From the factory the drums are drilled and tapped for M8 x 1.25 bolts. It's possible someone forced a 5/16" (7.9 mm) bolt through the hole. If that happened the correct metric bolt will no longer fit. Your options are to try a 5/16" bolt (either 18 or 24 threads per inch) or run a metric tap through the hole and hope you can restore the threads. |
Thank you
(Post 465280)
Thanks for the follow-up.
| All times are GMT -5. The time now is 5:34 AM. |
