2003 chevy tracker 2 door headlight problem
replaced fuses replaced bulbs but the driverside bulb is a lot dimmer then passenger side . a yellow color and if i put high-beams on it is about the same
any ideas ? thanks |
Check for good grounds at the bulb and also check the sockets that the bulb plugs into for clean corrosion free contacts.
| All times are GMT -5. The time now is 8:03 AM. |
