-   Tracker (https://chevroletforum.com/forum/tracker-26/)
-   -   2003 Tracker 2wd L4 2.0 base (https://chevroletforum.com/forum/tracker-26/2003-tracker-2wd-l4-2-0-base-121182/)
jkrisp2025 Nov 9, 2025 1:18 PM
I have a noticeable shimmy while braking at a stop light with the brakes applied. New motor mounts and tranny mounts installed. RPM seems good at about 850ish. Engine seems to be running smoothly otherwise. Shimmy goes away when driving. Any thoughts or suggestions?
L84sky Nov 10, 2025 3:48 AM
Replace your warped rotors or have them turned at a machine shop.
jkrisp2025 Nov 10, 2025 2:01 PM
Thanks. I will check into that.
-Nate Nov 10, 2025 7:37 PM
Not sure how warped brake discs could make it shimmy when stopped......
L84sky Nov 11, 2025 4:09 AM
The original post said: "...a noticeable shimmy while braking..."
-Nate Nov 11, 2025 7:24 AM
Can't Reed Gud =8-)
So it does ;
I saw "stop light" and went off course .
L84sky Nov 11, 2025 11:00 AM
I've done worse.
Rednucleus Nov 11, 2025 11:12 AM
I read this as shimmy or vibration when sitting at the stop light, not while moving. @jkrisp2025 please clarify!
L84sky Nov 11, 2025 12:09 PM
If shimmy means "rough idle" then I withdraw my rotor diagnosis and replace it with this:
https://cimg0.ibsrv.net/gimg/chevrol...bed3d9bb48.jpg
