Abs light on advice
ABS light come on if 4WD bulb indicator in cluster burned, even if not a tracker w/4WD or used, this happen to my, as soon change the bulb, ABS light go off. Why burned if not used ? don't know:confused:, but happen. check this before go to ABS diagnostic if you really don't have any other problem with the system.
