Camshaft Position Sensor Replacement
Hello Tracker Owners. New to this Forum. Can anyone please tell me the steps to replacing the Camshaft Position Sensor in my 2003 Tracker ZR2 V6 engine? Also where can I buy a service manual, prefer the actual book. Thanks everyone.
Actual books on repair are becoming obsolete these days it would seem..
Thanks oilcanhenry. I'm old school,I prefer the book.
Thanks oldchevy,I saw that. Don't know why they are expensive.
Now I just need the proper steps to changing the camshaft position sensor,please help.
Thanks all
Thanks all
OK I screwed up today. I managed to get 1 of the 2 torx screws out and yes I got the easy one out and I managed to screw up the one at the bottom and rounded the torx screw. Is there a way of removing the torx screw out without having to remove the intake? Those torx screws were really tight and I had a little trouble in getting the easy one out. Any help is much appreciated. Thanks all
Finally got the Camshaft position sensor replaced also changed the valve cover gaskets and the intake gaskets. Problem now is, I need to set the timing properly as it's not running right. I get a bit of a hesitation from a stop position and also got a flashing service engine soon after about 30-45 minutes of driving and got a pending P0300 code . I think it has something to do with the timing. How do I set the timing? Please help. Thank you all
YouTube!
