Electrical issues 2004 Silverado Z71
I have a 2004 Silverado Z71, 4WD, 5.3L, Extended Cab with electrical issues. It began with the radio time resetting to 12:00 am when i would start the truck and continues to this day. This later escalated to when turning the key the truck would start intermittently and when it didn't start there would be a clicking sound which was from the starter. Even later on when turning the key to the auxiliary position the dash lights might come on or just the check engine light and it would be dim and there would be no sound from starter when turning the key.
What i have done so far: Checked battery, Changed ignition switch, changed starter, cleaned ground wires on frame below drivers door, checked wires on throttle body (i did received a "low engine power") from dash display but only once during the last month or so since having the problem.( i changed the O2 sensors last year) I have read various posts on the same issue but with the changes i have had made it's still is not fixed. That said after changing the starter the truck will start after a couple of attempts (new starter still clicks on initial couple of try's). And once started it will start every time without clicking yet the clock will reset to 12:00 after every attempt. Codes i have received: P0120, P0220, P1516 these came in January but i have not had these come up again. At my wits end! Any help would be appreciated. Rgds ... Barry |
Issue resolved. Had the battery load tested and told it was fine but this was from the top posts only and not the side posts in other words how it is connected to the truck. The end result was the side post/s was faulty causing bad connection at times. Battery was a Sears model so won't be buying this brand again ... oh wait they are no longer in Canada so no worries ;)
Wish i would have looked at that at the beginning myself. Oh well live and learn. |
Originally Posted by Silverado2004
(Post 426908)
What i have done so far: Checked battery, Changed ignition switch, changed starter, cleaned ground wires on frame below drivers door, checked wires on throttle body (i did received a "low engine power") from dash display but only once during the last month or so since having the problem.( i changed the O2 sensors last year) I have read various posts on the same issue but with the changes i have had made it's still is not fixed. That said after changing the starter the truck will start after a couple of attempts (new starter still clicks on initial couple of try's). And once started it will start every time without clicking yet the clock will reset to 12:00 after every attempt. Codes i have received: P0120, P0220, P1516 these came in January but i have not had these come up again. At my wits end! Any help would be appreciated. Rgds ... Barry Thanks! |
Originally Posted by Ttucker96
(Post 473787)
Hey, were you able to troubleshoot what was wrong with your truck? My 2004 cateye is having the exact same issue.. Any advice??
Thanks! |
