Tracker 101: intro to the relays
https://cimg1.ibsrv.net/gimg/chevrol...17cd5dc22e.png
The 2001 Tracker has fourteen relays. Twelve of them are Single Pole, Single Throw (SPST). Only two -- the door LOCK and UNLOCK relays -- are Double Throw (SPDT). Thirteen of the relays are available under alternate part numbers. The Rear Defogger relay is discontinued although several Chevrolet dealers claim to have one on the shelf (for $100) https://cimg1.ibsrv.net/gimg/chevrol...47b0dd1102.png The A/C compressor relay is located on the relay rack under the hood. https://cimg9.ibsrv.net/gimg/chevrol...1621ff2078.png The A/C condenser fan relay is right next to it.. https://cimg4.ibsrv.net/gimg/chevrol...80fe44de4f.png The HVAC blower motor relay is behind the glove box. https://cimg7.ibsrv.net/gimg/chevrol...6efac64dd3.png The door lock relay is under the dash, left-center. https://cimg0.ibsrv.net/gimg/chevrol...4fa34efabc.png The door unlock relay is right next to it. https://cimg2.ibsrv.net/gimg/chevrol...8dffc6ac58.png The fuel pump relay is on the junction block. https://cimg5.ibsrv.net/gimg/chevrol...85c4f4ec6f.png The main (aka fuel injection or FI) relay is right above the fuel pump relay. |
https://cimg1.ibsrv.net/gimg/chevrol...4e3d01b570.png
The headlight relay is mounted on the Junction block. https://cimg8.ibsrv.net/gimg/chevrol...84ad96d6f8.png The tail light (aka headlight #2) relay is found below the headlight relay. https://cimg5.ibsrv.net/gimg/chevrol...f2a3cdc2aa.png The horn relay is located on the relay rack under the hood. https://cimg7.ibsrv.net/gimg/chevrol...d1cf5249bc.png The Oxygen Sensor heater relay is located on the fender near the windshield washer bottle. https://cimg7.ibsrv.net/gimg/chevrol...bc7e3688e5.png The rear defogger relay is found under the dash to the left of the junction block. https://cimg7.ibsrv.net/gimg/chevrol...599e9d18df.png The flasher relay is the one you never want to go bad. Although alternate part numbers are available, it's near impossible to replace. Note the picture above is step ten in the removal process. The prior nine steps describe unbolting the junction panel from the bulkhead. The flasher relay is not even visible when it's installed. https://cimg6.ibsrv.net/gimg/chevrol...9ac2030e78.png The only was to locate it is to find the white connector (C5) under tail light relay and turn on the emergency flashers. Reach one finger behind the junction panel where the white connector is and feel for a small clicking box. That's the flasher relay. |
