-   TrailBlazer (https://chevroletforum.com/forum/trailblazer-27/)
-   -   02 trailblazer rough on idle and coming to stop (https://chevroletforum.com/forum/trailblazer-27/02-trailblazer-rough-idle-coming-stop-56584/)
56 ford custom Feb 19, 2013 10:35 PM
I have had this car for alittle over a year now and it has been running pretty rough at idle and when you come to a stop if feels like it tens to shake and sometimes as if its going to shut off. Also I noticed now at a stop my "check gauges" light comes on and my oil pressure gauge is pegged at zero but when driving it goes away and is normal. Another problem I am having is that my volts gauge fluctuates and most of the time its no marks below 14. The last major issue I am concerned with is when I start up the car and shut it off the motor shakes a bit and like I stated previously at idle it does as well, I can feel it through the pedals and the steering wheel.
tymr287 Feb 20, 2013 9:56 PM
Just out of curiosity, when was the last time the throttle body was cleaned? Sounds like it struggling for air.
56 ford custom Feb 20, 2013 11:36 PM
trailblazer
To be honest....I have no idea. Whats the proper way of doing so? Whats to be used?
tymr287 Feb 21, 2013 8:05 AM
Get some carb/throttle boy cleaner & an old toothbrush. Hoold open the throttle plate, spray cleaner in it and on the toothbrush, and scrub. After I spray some on a rag then wipe it out. Put it all back together and start it up. Might run rough for a little bit, but it'll straighten out. See if that helps.
56 ford custom Feb 21, 2013 9:54 AM
trailblazer
Thanks a bunch! I will have to try that this weekend.
kvicars69 Mar 11, 2013 2:04 PM
04 trailblazer questions
Hello, I bought a 2004 Chevrolet Trailblazer and when i test drove vehical all was good, the next day after i purchased vehical it started idling rough at stops and red lights. I took to Mechanic and it was throwing 3 codes which all three pointed to O2 Sensor, took it back to lot where i purchased and they replaced o2 sensor and when i got home it started idling rough again. since then i have figured out it only does it when heat and air is off. any suggestions? also i figured out the the Check Engine light has been disabled, any suggestions on getting this light re-enabled?
Thanks in advance
kvicars69 Mar 11, 2013 2:05 PM
if it helps my 04 trailblazer is the LT model and the EXT 4wd
