gica69 |
April 18th, 2021 11:12 PM |
04 Trailblazer 2x4 noise while driving, only when going left on Freeway/not on street
This thing is pissing me off, I already changed the right front hub and it's still doing the same thing. It's basically doing it worse when on the freeway and there's a curve going left or if I drive straight at 25 mph and lightly pull the steering wheel toward the left and then straighten it again right away. Almost sounds like a flat tire sound, not so much grinding, dull noise. So if it's not the front right bearing, can it be the rear? Could also be the differential bearing/s right? I hope there isn't anything rubbing when on left movements, but unlikely. So I need some opinions here, thanks in advance for any help.
