05 Trailblazer PS leak from worm gear nut
i noticed a ps leak on my 05 trailblazer 4.2 looks like its coming from the tension /adjusting nut on the rack just below the steering shaft............its the nut that has an outer lock nut on it when you you loosen the locking nut you can tighten ./loosen the steering tension..............anyhow does anyone know if theres an o ring in there that my be causing the leak??
