2002 Traiblazer DTC P1221, P1271,p1484,p1484
Hello, I was hoping someone could help me with some codes coming up on my reader. I have the service engine soon light at steady on and every once in a while I get reduced engine speed light. The codes read p1221,p1271,p1484,p1484. I noticed someone had similar codes and it ended up being fan clutch wiring harness and was wondering if the same was going on here as well. Thanks for the highly appreciated forum site guys and any info you may be able to offer..
That would be the first place I would start
Thanks for your response guys its much appreciated. I still am not sure if I have a electro fan clutch or not. I am not getting any high pitch or overheating so I am leaning towards the wiring harness but cant locate it. The codes are a bit different than some others mentioned..
I reset the codes and tried the vehicle again and there was a loss of power with the reduced engine speed. So I checked the codes again and it only has one code P1271
Hellooo i need help
So for chanukkah i baught my boyfriend a 10inch dual sub box...it doesnt fit his truck...i need to sell it...please someone buy it. I need to buy him the right one. Please!!!!!!
Hi, I have a Trailblazer, 2002, with a fault code P1271, maybe you can help me please, it says APP
i need help p1221 and p1484 came out on the computer codes what this means trailblazer 2002
Welcome to the forum.:) P1221 is a "TPS 1/2 Performance" problem. The TPS actually has two sense circuits. The trouble code often indicates a correlation problem between the two since chances are only one circuit will develop a fault. Check the wiring:
Terminal G, GRY wire, TP Sens 1 5V Ref, to PCM connector C3, terminal 3 Terminal C, BLK wire, TP Sens 1 Low Ref, to PCM connector C3, terminal 59 Terminal A, DT GRN wire, TP Sens 1 Sig, to PCM connector C3, terminal 28 Terminal B, LT BLU/BLK wire, TP Sens 2 5V Ref, to PCM connector C3, terminal 49 Terminal H, BLK/WHT wire, TP Sens 2 Low Ref, to PCM connector C3, terminal 16 Terminal D, PPL wire, TP Sens 2 Sig, to PCM connector C3, terminal 30 P1484 is a "EV Fan Performance" problem. The Electronic Visco (EV) fan clutch is supposed to allow the fan to vary the rotational speed. The trouble code says the fan was running faster than desired which could mean an electrical or mechanical problem with the EV fan clutch. |
