Dtc p0449
I have read many posts concerning this issue....
I have 06 Trailblazer LS , 6 cyl. I bought the evap can vent solenoid valve from dealer, but cant find the location anywhere....dropped the spare tire, and see the canister mounted above a plate on drivers side, but not the vent solenoid. I havent removed the plate that holds the canister in place. could it be mounted above the canister? read where people only needed a screwdriver to replace it on the 07 model,so thought the 06 would be similar. pic would be nice, but info on location from canister will do fine. thanks in advance for any help you guys can offer |
update......reason i couldnt find it is because it wasnt there.....found bracket ....but no solenoid......maybe someone needed it more than i did, lol
anyway, location is just above rear differential, rear end of gas tank |
