Fuel leak
https://cimg2.ibsrv.net/gimg/chevrol...5bc9a7ade0.png
Fuel leak where vacuum line goes in to the vortec cover. Anyone deal with this? Any help in how to fix it would be appreciated. |
Originally Posted by Jeff Frahm
(Post 430738)
Fuel leak where vacuum line goes in to the vortec cover. Anyone deal with this? Any help in how to fix it would be appreciated. Looks like a vapor line to me. It's not the PCV. Likely you are going to need a new vapor canister which is why you smell gasoline. No way that is a gasoline line.. |
Yea, This is my son's vehicle, so I have not seen it other than this photo. After some research on the web. I believe the other end of that vacuum hose is connected to the fuel pressure regulator. I have a feeling the fuel pressure regulator is leaking and the fuel is going up that vacuum line and leaking out at the top where it goes in to the air resonator. I don't think there should be any fuel in that vacuum line. Pretty sure we just need to replace the fuel regulator.
