-   TrailBlazer (https://chevroletforum.com/forum/trailblazer-27/)
-   -   Help to Diagnose Compression Issue 4.2L (https://chevroletforum.com/forum/trailblazer-27/help-diagnose-compression-issue-4-2l-59406/)
struculeus Jul 18, 2013 10:42 AM
I have a 2005 Trailblazer with 4.2L, 85,000 miles.
I took a compression reading and came up with the following:
1: 40psi
2. 120 psi
3. 125 psi
4. 122 psi
5. 120 psi
6. 124 psi
The #1 cylinder is obviously the problem. The spark plug had a bit of oil on it.
Is the consensus that the problem is in the head / valve train? Or the piston / rings? Would it have anything to do with the variable timing solenoid?
I am wondering if doing a head job will fix this issue, or if I need to go full engine.
Also, I don't have a cylinder leak down tester.
Thanks in advance.
J
<!-- / message -->
MDTAHOE Jul 18, 2013 6:03 PM
There is only 2 ways to determine top end or bottom end issue. The easiest is a leak down test. Since you do not have one then you need to remove the head for inspection to see if you can see the problem.
