New Member needs help with headlamps
Hello!
You have a nice forum here. I was wondering if anyone could help me with my headlamp problem on my 2005 Trailblazer EXT (29,000 miles).
My brights are stuck on no matter what I do (manual or automatic setting). The headlamps go into normal mode when I remove the key from the ignition.
Your help is appreciated!
RE: New Member needs help with headlamps
haha. Bad fuse my friend. I went through this not long ago. When a headlamp fuse goes out, both the DRLs and the lowbeams come on to give you enough light to make it to where you are going {safety feature] Check all the headlamp fuses under the hood.
ORIGINAL: EuroGoldLS
The strange thing is the normal low beams come on after I park the vehicle and remove the key. Also, I forgot to mention, the low beams do come on sometimes during daylight hours. However, it doesn't seem to be related to the amount of light present. It may do it on a cloudy day or on a sunny day.
