Problem help me!!
So I have been havng this problem for about a month now. When I go to start my 05 TB the engine won't fire up after I turn it over the first time,or even the secon time sometimes. The starter is going and it turns ove, but it won't fre up.
When the engine does fre up, after the second or third time turning te key, smell gasoline. This makes me wonder if a fuel injecotr is going bad or possibly fuel pump or anoher issues. Any suggestions would be of great help. thank you |
This may seem crazy but I would try it, turn key to on right before the start position and turn back to off turn back to on, wait a second and turn it over. That will tell the pump to pump twice and the injectors to pump twice I believe. It's worth a shot.. But I don't know why you'd smell gas?? Let me know how it goes hope this works if it does it is probably your injector and or pump like you said..
You need to find where that leak is. Smell of gas is a leak
| All times are GMT -5. The time now is 7:31 AM. |
