Trailblazer help
How to fix the speedometer on a 2002 trailblazer 4.2. I've already replaced the speedometer and the speed sensor and it still doesn't work. Any clues on how to fix?
know anyone with a full function scan tool that can do a cluster sweep?
the cluster you put in is used or new? |
Stepper motor
The stepper motors go bad in must of the Trailblazers. Swapping them out usually works. Disassemble the cluster and there are 4 spots on the backside of the stepper motor. Unsolder and replace. Should be fine after
| All times are GMT -5. The time now is 3:41 AM. |
