2012 issue help
Ok need some help. I think I might know issue possibility short in rear left door harness.
Started with window not working, replaced regulator and found possible short by moving it around between door/body. Now noticed the following issue: 1. Radio not shutting off after key and door. Does after 10 min due to battery saver. 2. No dome light 3. Hood open displayed. 3. Doors not communicating with scanner. Open or closed. 4. Door lock switches not working. Works fine with fob and auto lock functions. 5. Wiper washer will not work when pressed. 6. Just found out turn signals no longer working. I'm thinking if really a short in door harness not allowing everything to communicate with body control module. What your guys thoughts. |
| All times are GMT -5. The time now is 4:02 AM. |
