2015 traverse engine clicking sound?
Hello my engine is making a clicking sound under the cover any ideas what it could be?? I uploaded a video but not sure if it worked….
Originally Posted by lacey
(Post 490069)
I never saw a vid, BTW. |
1 Attachment(s)
(Post 490070)
Likely lifters going bad or becoming loose, You will have to adjust them.
I never saw a vid, BTW. I think I got the video uploaded now… |
At what RPM's is this at? It does indeed sound horrible to me.
(Post 490073)
this is at idle car in park a few minutes after starting it |
(Post 490076)
Purge Valve will make this noise when hot or getting old. $50 max and very easy to replace. One thing to test is with the cover off and it is ticking unplug the valve right in front of you by squeezing the plug and unplugging it. If ticking goes away, there's your culprit. By now you may have figured this out. Good luck!
| All times are GMT -5. The time now is 10:37 AM. |
