Front washer motor not working
2012 Traverse LT
front washer motor wasn't working so I figured it was a bad motor. It wasn't. Check the under hood fuse and its fine, check the fuse under the passenger dash and its fine. Pulled relay out that's under the passenger side dash and its fine, plus I swapped relays and still no front washer motor power. I'm not getting power at the fuse that's under the passenger side dash. From looking at a wiring diagram, power comes to the relay then to the fuse that's located under the passenger side dash. So to me it seems the issue could be the 12v wire from the battery to the relay. Anyone run across this issue? |
Originally Posted by Rubberman01
(Post 475442)
2012 Traverse LT
Originally Posted by kevinkpk
(Post 475447)
Well, I'd recommend with voltmeter check for power at the relay coil from the switch, if not there, check for power to the switch.
(Post 475453)
Its near impossible to probe the relay slot. Its up underneath the dash and I can barely get my hand in there. I don't think it could be the switch cause looking at the wiring diagram the 12v comes from the battery to the relay then fuse.
I think I am thinking wrong. There won't be 12v at the under dash fuse until the button is pushed. you are right about being the washer switch.
(Post 475460)
I replaced the multi function lever and it works now.
(Post 475442)
2012 Traverse LT
Replaced my switch/lever washer still did not work.
(Post 475575)
| All times are GMT -5. The time now is 7:21 AM. |
