-   Traverse (https://chevroletforum.com/forum/traverse-63/)
-   -   No sounds in my traverse (https://chevroletforum.com/forum/traverse-63/no-sounds-my-traverse-88509/)
cheenash Jan 15, 2018 12:57 PM
we have a 2011 traverse and there is no sounds, no chimes no radio nothing however the lights are on on the radio and signals work just NO SOUNDS... What can I do???
oldchevy Jan 15, 2018 1:10 PM
The first thing to always do with electrical problems is to check all of your fuses.
tech2 Jan 15, 2018 1:34 PM
starting point; the chimes are produced by the radio and MIGHT broadcast out the l/f speaker.
cheenash Jan 24, 2018 12:14 AM
I have checked all fuses and their fine.. any other suggestions?
cheenash Jan 24, 2018 12:15 AM
Okay.. where is this located?
tech2 Jan 24, 2018 4:51 AM
check for radio fault codes with a scan tool. you will need a scan tool that reads body codes. if the radio doesn't work, you won't have chimes. if you checked all the radio fuses...pull the radio and check for power and grd at the radio wiring harness. if power and grd are present. the radio is nfg. if you replace the radio with aftermarket...you will also need a chime module to produce the chime sounds.
vipergg22 Jun 14, 2018 6:33 AM
Your driver side speaker is probably trashed. GM used cheap $10 speakers in their cars for the standard radio and inevitibly they go bad . I have a 2008 Ascender which GM made and have replaced all 4 of mine with Pioneers and have never had another issue . All the sounds for the dash and alarms run thru the front driver side speaker .
Norris Campbell Nov 11, 2019 4:14 PM
No sound from my speakers, tho' the radio works.
could someone please tell me where to locate the speaker fuse?!
I see a fuse for EVERYTHING but the speaker fuse.
Is there even a fuse dedicated strictly for the speakers?
mountainmanjoe Nov 11, 2019 4:45 PM
no. I've never seen a speaker fuse. Shorting a speaker wire usually doesn't have any cataclysmic consequences.
Irish_alley Nov 12, 2019 10:18 AM
could also be an amp. my o4 imp has a radio issue where the xm radio and AM radio work just fine but theres very little sound from the FM radio
