Where do I get ignition powered 12V from the passenger side electrical box
I am running a radar detector hard-wire and would like ignition power 12V and not always on. Which fuse or power supply can I use. Right now I am using the seat heating/cooling power source - but it seems to be always on.
I read a forum where a member installed a Parrot bluetooth kit-
I believe he ran a power wire to the fuse box under the hood- as theres an extra powered fuse there-- whose power also goes out after 10 min. |
just take a quick splice and connect your radar detector wire to your ignition wire. ill find a pic of one.
http://shop.oreillyauto.com/ProductD...goryCode=3067E |
Would not suggest tieing into ignition wires at ignition harness. Those are low voltage/amperage. There is a switched (RAP) circiut at BCM.
a radar detector is low voltage also. probably be ok to tie it into where the ignition wire goes up to the ignition under the steering column.
someone sells a wire that allows you to plug into the power in the rear view mirror...
if you have onstar/camera etc... you can plug in directly here.... here you go... http://www.invisicord.com/ |
| All times are GMT -5. The time now is 1:09 AM. |
