2005 uplander dvd system
We bought a used 2005 uplander and it actually had the remote and wireless headsets in the original packaging (bonus for us) however the dvd system won't play over the main speakers! we read the manual over and over and tried everything we could think of and nothing has worked. Please help! Thnx in advance!
RE: 2005 uplander dvd system
We bought a used 2007 this summer. I tried and tried using the instructions in the manual to get sound from DVD from the speakers (headphones work fine) asked salesman and he said its illegal to listen to DVD over radio speakers so there is no way to send sound to them. If anyone knows how to do this I would like to know too.
HAHA.....the only thing illegal about video systems, is that the driver cannot watch it while driving. You can listen to whatever you want to while you drive....including the dvd player.
Turn the dvd player on, put in a dvd in and hit (I THINK) band, or cd...forget what button it is. If it doesn't work, then either the radio is not setup properly, or there is another problem in the vehicle. Either way the audio SHOULD come through the speakers and it is not illegal |
Late is better than never...
So I'm a little late to the party, but I had this same problem, and I figured out the answer. In my 05 Uplander, the button to push is called CD/AUX, and it's located on the main radio up front. Pressing it should play the DVD audio through the speakers...and no, it's not illegal. Attempting to watch the DVD player as the driver is though.
dvd player wont take dvds
i just got a 05 uplander a little over a month ago i have tried to put a dvd in the dvd player over head and it seems like there is a dvd stuck in there but when i hit eject nothing comes out and it displays no disk ... then sometimes while driving it just starts making a noise like its running and trying to eject any help would be great please
Originally Posted by my2divas
(Post 297499)
A couple days later, I found some links online about how to take the DVD player down and take it apart. It was actually pretty easy once I found the right tools. (You need a very long Phillips head screwdriver) I took everything apart down to the disc drive and found that a panel in the DVD player (where the disc goes in) was bent. I bent it back into place and put everything back together. I literally prayed it would be THAT easy and that it would be fixed. I re-installed the DVD player, and VIOLA! It has worked perfectly ever since. I don't know if your DVD player has this same issue, but the point of my story is it's not that difficult to take it apart and have a look. I took the DVD player down, took it apart, reassembled it, and re-installed it in about an hour total. |
Originally Posted by jbonsall
(Post 75393)
I think the very first thing to asses is that you need to specify exactly what kind of DVD you
are trying to play in the roof mounted unit And as it says above if it's a playable/accepted DVD , the way to enable it is by pushing the button on the radio up front marked CD/AUX By pushing that button you are telling the radio up front to start up the DVD player mounted above and shut off the CD player/radio up front A storebought DVD or CD is a foolproff disc to start with in the upper DVD player as a test to check if the unit works and to see if the sound comes through the system Home made music DVDs and CDs burned on a PC will also play fine in the upper DVD player but the songs have to be burned in the MP3s or WAV format Since a DVD will hold more music then a CD I can usually get over 700 songs onto a DVD disc converting the MP3s from FLACS at the highest bit rate my converting program will do 320Kbps You can use DVD+ or DVD- and also rewritable DVDs as well as rewritable CDs Quality compromise in the music is irrelevant given the basic sound system in the van , that many songs on 1 disc is O.K. for long drives The titles , artist name , album name will show up on the radio up front as the songs play on the DVD , the songs can be advanced as well from the radio up front and it's quite possible that with the remote you can skip a bunch of songs at the time You can burn the songs in folders by genre or decade , you can number the songs so they will play in the order you prefer The unit will decipher in alpha-numerical mode If you don't use folders you can put a genre word in front of each song to group all songs from a genre together , the individual artists will then automatically be organized by name which makes it easy to find an artist on the disc The screen on the DVD player will also show all the info as the songs play through , the remote can also be used to navigate through the disc The remote and headphones will keep teenagers and kids quite busy on long trips We use the CD player up front with a few hundred favs on a CD disc during short drives , and one DVD in the upper unit for longer drives The Upper DVD player also has an audio video input , you can easily connect a cable from a phone or MP3 player to stream the music while sitting in the back of the van You can do the same on the radio up front since it also has a mini jack input , you can buy a cheap unobtrusive $15 Bluetooth adapter with a built in mini jack and leave it plugged in up front avoiding cables ....while living with the crappish audio compromise :o When I get around to it I will try a few home made Video DVDs to see what formats the DVD player will play back I will also take a look to see if it's possible to move the light behind the DVD player further back since IMO it's too close to the DVD player The extended Uplanders will convert easily by removing the seats and will sleep 2 comfortably while still carrying a pile of crap IMHO the sound system and DVD player is basically gravy since it was already installed and I won't need to upgrade as I've done in most of my rust buckets Cheers ...... Vinny |
