2007 uplander possible ball joint ot tie rod. please help
i have a 2007 uplander. my abs light just kicked on. the driver side front wheel has play side to side(9 and 3 oclock position) but solid from top to bottom (12 and 6 oclock position). Im leaning toward wheel bearing since my abs light is on also. Would this be tie rod or wheel bearing? thank you
9&3 movement is usually, a outer tie rod end, inner tie rod end or lower ball joint.
that's what I was thinking but when the abs light came on, it through me off. I also get a clicking sound when driving straight from that wheel. sounds like a piece of gravel in hub cap. would outter tie rod make that clicking sound?
...no
