2008 uplander transmission issues
I've never had problems with my transmission slipping, however only sign i had was in the first 30 seconds after starting i could hit the gas and it wouldn't do anything for a second but then jerk forward and then work great the rest of the trip. I woke up yesterday and started it up, let it warm up inside before taking my kids to school and to find it not going into Drive. I didn't find out until after i backed out of my driveway that it wouldn't go into drive, it wouldn't go into 3rd drive but the lower gears worked. I quickly found out that i could shift it into drive as if i was using it as a stick shift.
I started being an internet mechanic right away and saw that replacing the pressure control solenoid is a pretty common problem right around 100k. So i thought to myself awesome, only a 400-500 dollar fix and i can be driving in it tomorrow afternoon again. I take it to a transmission shop (my biggest mistake i believe) and they told me to leave it because they couldn't even diagnose it for 4-5 hours because of how backed up they was. So I left it and started walking home, (20 minute walk) and half way home i get a call from the shop, " oh hey your transmission is completely dead, and need a rebuild and we need 2k + tax". This sounds extremely shady to me, they told me they didn't even get Solenoid error codes and wouldn't go into details of what codes they got other than it was dead. I know it needs a 2nd opinion, but this seems far fetch that a transmission would just go completely dead overnight. |
Originally Posted by clm911978
(Post 365714)
Another shop told me that it could just be the pressure plate since i can still get the car into drive while upshifting(its gotten 20 degrees colder within the past 3 days), another shop quoted me 1895 for a rebuild, i just think its the area i live in fighting over business .
QUOTE=clm911978;365726Another shop told me that it could just be the pressure plate since i can still get the car into drive while upshifting(its gotten 20 degrees colder within the past 3 days), another shop quoted me 1895 for a rebuild, i just think its the area i live in fighting over business .[/QUOTE]
Probably meant the drive plate. Pressure plates are for the clutch in a stickshift. Automatics use a flex plate to start the vehicle with the starter. |
How long have you owned the van and how many miles are on it?
Did you change the transmission fluid in the past? |
Originally Posted by Papa Bear
(Post 365739)
op what did you end up doing?
fwiw, occasionally mine has trouble finding D when i pull the lever. recently it stayed in N despite the dash saying D.. as you did, i moved it to 1 and rolled it down the street.. stopped, put it back to P, then it found D again. hasnt done it since. oddly it happened mid november which i believe was right around the first cold weather here. |
I have had the same problem for a year now and have drove over 20k miles it hasn't go
(Post 365714)
