Blend door actuator ?
When it gets real cold I get sometimes only get cold air. I think that the blend door is sticking or the actuator is going bad. I almost afraid to ask ! but how do you get to the blend door and actuator?
Thanks Joe B |
what year? single zone or dual zone? Are both of the heater hoses hot?
OOPs, sorry, forgot that important info... the Uplander is a 2005 with single zone heater. The heater is back to working fine. The only time I seem to have a problem is when it gets real cold, like the other day when it got down to zero... then It's blowing only outside air. Since it works OK otherwise i'm thinking that the actuator is OK and the problem is that when real cold the housing ( plastic I guess?) shrinks and binds the blend door. In any case I need to get in there and check it out.
Joe B |
Temperature Valve Actuator Replacement (Single Zone)
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=1536779&pubCellSyskey=63237&p ubObjSyskey=1536779&from=sm&laborOpCode=&cellId=63 237#ss1-1536779">Removal Procedure
Actuator Recalibration
When replacing the HVAC control module, it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC control module, be sure to perform the following: Important: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted, improper HVAC performance will result.
When installing the HVAC actuator be sure to perform one of the following: Important: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted, improper HVAC performance will result. Preferred Method (w/Scan Tool)
improper HVAC performance will result. Alternate Method (w/o Scan Tool)
Shawn, thank you very much...
Joe B |
good luck!
Hello, would a 2004 Chevy Tahoe use this same HVAC control module calibration?
Alternate Method (w/o Scan Tool) Clear all DTCs. Place the ignition switch to the OFF position. Connect all previously disconnected components. With the Mode knob in the PANEL position, press and hold the AC button for 5 seconds. Rotate the Mode knob fully counterclockwise. Rotate the Mode knob fully clockwise. Rotate the Mode knob fully counterclockwise. Release the AC button. Wait 40 seconds for the HVAC control module to self-calibrate. Start the vehicle. Verify that no DTCs have set as current DTCs. |
2001 Buick Regal
Any pointers on installing a replacement Air Door Actuator on a 2001 Buick Regal with Dual Zone cliamte control? I am currently getting Cold air on the Driver's side and hot air on the passengers.
Thanks |
heat not working
air conditioner works fine but, heat wont come on. blows cool air out when on heater. coolant level is fine and no leaks in car like the heater core is broke so wondering what problem could be. Thanks.
| All times are GMT -5. The time now is 3:30 AM. |
