How do you program new remote keyless entry for 2007 Chevrolet Uplander?
Is it diffrent to program 07 uplander (keyless remote)?
06 uplander program does not work... |
RE: How do you program new remote keyless entry for 2007 Chevrolet Uplander?
Transmitter Programming [/align]
Important: All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to 4transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. [ol]Install a scan tool. Use the scan tool in order to access programming: Vehicle Control System/Computer Integrating System/Module Setup/BCM/Program Key Fobs. Press the START soft key on the scan tool. Important:The scan tool must stay connected until all of the transmitters are programmed. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 5-10seconds, the scan tool will indicate that the transmitter is programmed. Repeat the previous step in order to program up to 4transmitters. Remove the scan tool. Operate the transmitter functions in order to verify correct system operation[/ol][/align] |
ORIGINAL: shawnvw Transmitter Programming [/align] Important: All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to 4transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. [ol]Install a scan tool. Use the scan tool in order to access programming: Vehicle Control System/Computer Integrating System/Module Setup/BCM/Program Key Fobs. Press the START soft key on the scan tool. Important:The scan tool must stay connected until all of the transmitters are programmed. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 5-10seconds, the scan tool will indicate that the transmitter is programmed. Repeat the previous step in order to program up to 4transmitters. Remove the scan tool. Operate the transmitter functions in order to verify correct system operation[/ol][/align] Thanks Frank Michigan |
Pretty sure just the GM Tech2
It only takes a few minutes to do if you have to get the dealer to do it |
ORIGINAL: shawnvw Pretty sure just the GM Tech2 It only takes a few minutes to do if you have to get the dealer to do it Gotta get in good with a shop's son I guess |
