how to program uplander keyless entry fob diy?
i know the vehicle had one from the factory because the prior owner had a working one the first time i test drove it... they lost it before i bought the van. i have an unprogrammed remote fob but its been slow-going searching for programming directions... i have an elm327, but havent tried forscan. any tips? thanks
It depends on the car, but, the recommendation would be to get it reprogrammed using a GM Tech-II Scanner.
No way to program without a scan tool or programmer, and not one of the cheap ones
Either dealer or locksmith (usually cheaper). I have a Snap-On MODIS and was able to use it. |
i wonder if forscan can do it, but unfortunately i will likely never take the time to mess with it
Originally Posted by 12three
(Post 364501)
Originally Posted by BobV
(Post 364516)
FORscan is Ford (Lincoln) only.
that must be why i never bothered with it.. i only need advanced capabilities for my chevys... hopefully somebody chimes in with the gm equivalent of a forscan type app |
Keyless entry systems have become a staple in the automotive world, and their use is as widespread as power windows. The remote is programmed to work with one specific vehicle, and the vehicle will usually come from the factory with a couple of remotes already programmed to be used with it. If these remotes get lost or stop working, it is possible to order more remotes that will work with your vehicle.
The Chevrolet Uplander keyless entry system relies on remote transmitters for access to your vehicle and control of the lock system. You can add up to four keyless entry remotes to the Uplander's power lock system. Save the expense of visiting a dealer by programming the new remotes at home. Buy a replacement remote from an auto parts retailer or Chevrolet dealer.
