Squirrels made nest and chewed through wiring under hood of my 05 Uplander
Hi guys I am having trouble finding the correct part and repair method to fix this mess. Squirrels made a nest in my uplander under the hood and in the process chewed through 3 spark plug wires and what I believe is the wires leading to the MAF sensor. Here are pics of the damage. The MAF sensor itself is fine and i can disconnect the connector that plugs into it in the intake. But what is the part i will need to get, an MAF sensor harness? Is there a part number? Can these wires be spliced rather than running a whole new set of wires through the wire tubes (or whatever they are called) to the other side? The plug wires should be no problem to replace it's the MAF wires I am not sure on.
Well I solved this, if anyone has the same issue, since I could find no info online about this, here is the part i found at a brick and mortar near me it's an MAF Sensor Connector, I also saw these advertised as "pigtail harness" https://www.napaonline.com/en/p/ECHEC759 they were a lot cheaper online but I needed it today, also picked up a set of spark plug wires and some rodent poison to discourage the squirrels, this is the second time they have made a nest in the last 2 weeks. The box came with 5 butt splice connectors so I will just need to strip the good wire ends and use the butt splices to connect to the new MAF connector and crimp them on.
