uplander09
no display on dashbord whats the problem,also no radio, check fuses ok
is anybody had that problem before the display not working at all
If you are sure it is not a fuse problem, then it's either the Instrument Panel, or the bulbs inside it are burnt-out.
I'm not sure how to remove the instrument panel. I had an issue with the DIC not working and had to get the dealer to fix it. Fortunately I bought my van as a Certified Pre-Owned vehicle which covered this under the 3 month warranty. Good luck and let us know how you resolved this. |
