2000 Venture hose from aux water pump
1 Attachment(s)
I just did an intake manifold gasket job on my minivan and it's mostly put back together. I can't figure out where this hose connects. Any help? I'd greatly appreciate it!
It's an extended Warner Bros. It had the dreaded faulty intake gasket. If I can get this hose connected. I'm an hour away from being done! Hopefully it didn't belong under the upper intake/plenum. ;) Thanks! Attachment 18629 |
2 Attachment(s)
If you are referring to this hose:
Attachment 18627 Then that hose is for coolant back circulation from heater core, it should plug in back there - see red arrow. Attachment 18628 |
1 Attachment(s)
Thanks! I tore the plenum off the intake again to get to it and snapped this picture as a reference. I couldn't quite see the hole in your picture, but I saw the protrusion. Thanks again!
Attachment 18626 |
