2002 Avalanche 4x4 leveling kit
I am about to purchase an avalanche and am going to install 3in keys in the front, and 2in coil spacers in the rear. I have seen avalanches before that people have ran 35s without an actual lift kit. What else would I need to install on the truck to be able to run 35s and I know tire rubbing will happen. Right now I have 17in factory wheels and can change those to aftermarket if need be. All help is greatly appreciated.
2004 Avalanche
I have a 2004 Avlanche 2500. I had the levelling kit installed at the lowest setting. (OK4wd.com in NJ) They said this is about 1.5" lift. I had to put 1" blocks on rear axle to make it look right. I have 285 tires that measure 32".
They rub a little. I'm not sure, but I think you need to go up more then 2" to run 35s. Esp if you have 1500. Call OK, they are good guys
Droptine
2007 - 2013 (GMT900)
13
February 10th, 2016 6:06 PM
JohnHickey20
Silverado & Fullsize Pick-ups
June 28th, 2014 6:23 AM
du1973
December 3rd, 2009 10:33 PM
