Chevrolet Avalanche
Platform: GMT 805 & 900
siege conducteur chauffe tout seul ???????
Old April 11th, 2013, 3:10 PM
PAT AVALANCHE's Avatar
Default siege conducteur chauffe tout seul ???????
Bonjour a tous,j'ai un avalanche de 2003 Z71,le voyant du siege conducteur s'allume tout seul en roulant,je l'eteint quelque moment apres il se ralume tout seul et le siege chauffe,de temps en temps il recommence,j'ai remplacé la platine electronique du bouton,mais ca recommence ce n'est pas ca!! d'ou est ce que cela peux provenir??
merci de votre aide,j'espere trouver des passionnés ici
Old April 11th, 2013, 3:25 PM
kevinkpk's Avatar
No poly vue Francias. You have a climate control issue.
Old April 13th, 2013, 1:46 AM
merci kevinkpk,mais mon siege se deregle plus que le climat quel temps fait il chez toi,ici il pleut..une solution pour le siege ????help please...
Old April 13th, 2013, 7:05 AM
kevinkpk's Avatar
You will have to translate to english. All I get out of it is climate control problem.
Old April 13th, 2013, 12:44 PM
tymr287's Avatar
I did a translation, this is what I got that he said.
Hello to all, I have a 2003 Z71 avalanche, the driver seat light alone while riding, I turned off any time after it is ralume alone and the seat heats, from time to time it starts again, I replaced the electronics of the button deck, but ca again this isn't ca! where is what it can be?
Thank you for your help, I hope find enthusiasts here
Thanks kevinkpk, but my seat to field more than climate what time is it home, here it rains...a solution for the seat?help please...
Old April 13th, 2013, 12:51 PM
kevinkpk's Avatar
Thanks for the translation. You guys with heated seats, and I've read several issues with them, post here, or if admin would move this to a more appropriate/technical post, I am sure Pat Avalance will get more responses.
Old April 16th, 2013, 3:35 PM
kevinkpk hello, what is it that "climate control", I replaced the electronic board in the car door, but it is not AC, thank you for your opinion, this is a car excelllente
Old April 16th, 2013, 3:37 PM
kevinkpk's Avatar
Is the seat heater the issue?
Old April 17th, 2013, 3:12 PM
yes it is heated driver's seat, it triggers alone from time to time
Old April 17th, 2013, 3:48 PM
kevinkpk's Avatar
Go to search at the home page of this forum, then type in heated seat (suggestion) this should bring up thread on this issue. I done have heated seats, but have seen threads/posts on them.
