Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
92 Corsica brake master cylinder replacement has turned into an anxiety disorder!
Old November 23rd, 2015, 8:09 AM
happytrayls's Avatar
Default 92 Corsica brake master cylinder replacement has turned into an anxiety disorder!
I don't see any thing on how to properly disassemble the abs modulator to get at the banjo bolts located behind the mod cover letter hat is bolted to the base that is bolted to the housing....yada yada.should the rear pistons be reset before I disassemble the unit as in the bleeding procedure?
