Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
Clock stays lit
Old February 12th, 2017, 11:45 AM
zabbie88's Avatar
Default Clock stays lit
Why does my clock stay lit when key is off, draining battery?
Old February 12th, 2017, 12:12 PM
Gravydog316's Avatar
Did it just start doing this?
Some of them DO stay in 24/7.
If it a recent thing, try disconnecting the negative (black) battery cable, then the positive (red) cable & let it sit for about 15mins.
Then, connect the positive first, then the negative back to your battery. & try to make sure you don't get sparks.
(I don't know if it will work, because some of those clocks DID stay on 24/7.
Unless it drains your battery, then it shouldn't be a problem. :-)
