2016 Camaro
Platform: F-Body & Zeta.
fuel tank pressure sensor
Old January 6th, 2012, 1:32 PM
Wildflower's Avatar
Question fuel tank pressure sensor
Hello, i am new. I need help with a 2000 chevy camaro fuel tank pressure sensor, where is it located at, i have been looking it up, and found nothing. And is it hard to do, or can i do it myself.
Old January 6th, 2012, 5:23 PM
EinST's Avatar
The FTP sensor is attached to the fuel pump module, on top of the fuel tank. If you have the facility to drop the fuel tank, go for it. Otherwise, consider getting it serviced (ask them to fix the problem, not just replace the sensor since the problem may be in the wiring).
Old January 6th, 2012, 9:28 PM
Wildflower's Avatar
Thank you. I took it to autozone so they could read the error, and it said it could be the FTP sensor or the canister purge solenoid. I would love to do it myself.
Old January 6th, 2012, 10:05 PM
EinST's Avatar
And, they'll gladly sell you both parts (crummy aftermarket parts with lifetime warranty, no less), so you can keep throwing parts at the problem. You can try the purge solenoid first and hope it's not in the wiring. If that doesn't do it, consider taking it in for service.
Old January 7th, 2012, 12:24 AM
Wildflower's Avatar
Thank you very much, I will do that
Old January 7th, 2012, 9:23 AM
EinST's Avatar
You're quite welcome. I sincerely hope that takes care of it because the other possibilities are quite a hassle.
Old January 7th, 2012, 11:34 AM
Wildflower's Avatar
Question: why would it be the wiring, is there a known problem?
Old January 7th, 2012, 5:07 PM
EinST's Avatar
None that I know of. It's just that the wires run front to back (basically the length of the vehicle) and thus tracking down a wiring fault can be time-consuming.
Old January 8th, 2012, 11:51 PM
Wildflower's Avatar
ok thank you
Old January 9th, 2012, 12:00 AM
adam86107's Avatar
I had the problem on my 01 right after I bought it and had the dealer that I bought out from replace it. It cost 500 bucks and they had to remove the exhaust and the tank.
Quick Reply: fuel tank pressure sensor
