Platform: J-body
99 Cavalier dead
Old Oct 9, 2011 | 4:06 PM
Hal's place's Avatar
Default 99 Cavalier dead
I went to work yesterday and when I came out the cavalier won't start, lots of battery but no spark, any idea's where to start looking?
Old Oct 9, 2011 | 6:39 PM
EinST's Avatar
The ICM is powered through the 20A IGN fuse. It's responsible for producing spark through the 1-4 ignition coil and 2-3 ignition coil. It need the CKP sensor input to determine which coil to energize. If you're sure your problem is the lack of spark, the above are some of the things that come into play.
Old Oct 9, 2011 | 10:10 PM
Thanks, do you now where the CKP sensor is located on the 2.2, and if I can test with an ohm meter?
Old Oct 9, 2011 | 11:05 PM
EinST's Avatar
It should be right next to the ICM. It takes an electrical connector with two wires, YEL and PPL. It's a Hall effect sensor that generates weak voltage pulses as the engine turns over. Do you have a multimeter that can do O-scope?
Old Oct 12, 2011 | 10:01 PM
I checked for spark at the end of the plug leads (no spark), checked voltage at the module (12.4V), trying to check the crank shaft sensor were it was located seemed ugly so I spent $12 and changed it, still no spark.
Old Oct 12, 2011 | 10:28 PM
EinST's Avatar
No spark at any of the plugs? It's hard to believe both coil packs went bad all of a sudden but anything is possible. I simplified the role of the ICM but it actually send the CKP sensor information to the PCM and gets the spark timing signals in return. Is the PCM powered, i.e., 10A CLS/PCM fuse and 10A PCM/IGN fuse in the fuse block and 10A PCM fuse under the hood okay and has power with key on?
jggolf
Nov 30, 2014 12:17 PM
EpiphanysLyric
Sep 25, 2013 10:30 PM
ollie2009
Aug 30, 2011 10:17 PM
