2000 2.2 starts sometime but I need it to start all the time
#12
yeah that's different from mine I have a crank position sensor and if that failed I would either have no spark or it would spark at the wrong time which would be very noticeable that's not my problem. Thanks for helping I guess I just have to keep pushing forward
#14
Heah tech2 we have yards that part out the cars and then warehouse them. I am not aware of any u pull yards around. We had a bunch of them in PA but here its different. I am not sure they even keep the gas lines. If so they would want to sell the entire line for big bucks I am sure.
You said you bought the ends. What exactly were they? I know they come in the Master Test Kits so someone makes them. I really want to see what the pressure looks like.
Thanks
Thanks
#15
and I forgot to take the fuel line home...I will post tomorrow
I just went into napa and asked for there fuel line repair quick connects...they brought me out a whole bunch and I matched it up...I will see if I can find the part #
#16
Great I am hunting a Napa store. My friend says there's one nearby. I will use your part numbers. That should fix me up. Thanks
#17
Well NAPA said they only can get the male end for $16 so I decided to find these things. I found them on Amazon OTC set gives both the male and female 3/8 for $20. I was then able to return the tester I got from Autozone. I then bought one from Harbor Freight. it did not have the bypass but that was easy with a few brass fittings and a shutoff and piece of 1/4 hose. I now have a tester with bypass that cost me total $25 (including fittings)and then the ends for $20 for a total of $45 which is less than the tester I bought from Autozone which I still needed to buy the ends. The ends will be here next week from Amazon so I will be able to check pressure then. I will post my findings when I get them next week.
Thanks
Thanks
#18
Findings
Ok I finally got the ends and I checked fuel pressure. I had nothing! No pressure no flow. The fuel pump was running when key turned but no flow. I then took a bat and hit the tank and the fuel started flowing. I was not able to get a pressure reading because the HF gauge leaked gas everywhere but The car then ran. So it is a definite bad fuel pump even though the pump was running. I need to change out the pump and I will have a running car again.
Thanks all for the help.
