Platform: J-body
Bleeder valve location
Old August 28th, 2011, 6:05 PM
tiger8522's Avatar
Default Bleeder valve location
Hi,
I am new to this board and I am attempting to change the coolant in my mom's car. I have a manual that shows several locations for the bleeder valve but all of the locations that they provide do not have a bleeder valve in those locations. It also states that some of them do not have a bleeder valve. My question is can anyone tell me if her car is equiped with a bleeder valve and if so where would I find this. The enging is a 2.2 LT, automatic trans. Thank you for any help that you can give me.
Old August 28th, 2011, 9:10 PM
spedaleden's Avatar
What year is it
Old August 29th, 2011, 5:41 PM
DHoShow's Avatar
You may just have to remove the lower rad hose and let it drain out there
Old August 29th, 2011, 6:37 PM
i believe op is trying to purge air out of the system after the drain and refill.
Old August 29th, 2011, 8:41 PM
kevinkpk's Avatar
That will do it.
Old August 30th, 2011, 6:08 AM
tiger8522's Avatar
The cavalier is a 2003, and you are correct I am need to purge the system of air after I drain and refill the system.
Old August 30th, 2011, 7:12 AM
your manual is showing bleeders for the 2.4l engine option. the 2.2 doesn't have them. lower rad hose it is i guess.
wis2ohio
December 26th, 2013 7:13 PM
kevilay
April 10th, 2013 11:18 AM
cumminbr
Silverado & Fullsize Pick-ups
August 13th, 2011 6:20 PM
Newbee
December 1st, 2010 12:52 PM
ruffrider285
March 6th, 2008 6:28 PM
Quick Reply: Bleeder valve location
