Platform: J-body
Bad/leaking wheel cylinder
Old January 1st, 2016, 3:22 PM
That_guy's Avatar
Default Bad/leaking wheel cylinder
My brakes go down to the floor. I have replaced the brake cylinder that was leaking. But it is still leaking from the exact same spot. Ive checked all other brakes and hoses, there are no leaks elsewhere. Please help.
Old January 1st, 2016, 4:22 PM
Rednucleus's Avatar
Make, model, year may help us and pictures are always nice.
BTW welcome!
Old January 1st, 2016, 5:32 PM
is the leak at the line into the back of the wheel cylinder or past the pistons seals?
the line would indicate a possible problem with the flare in the line, the seals would indicate a bad replacement part.
Old January 11th, 2016, 4:33 PM
That_guy's Avatar
BTW welcome!
2005 base model 2.2 ecotec sedan
Old January 11th, 2016, 4:35 PM
That_guy's Avatar
Not at the line. Would replacing the wheel cylinder again fix it since the part is bad?
Old January 11th, 2016, 7:12 PM
if you pull the rubber dust covers back and fluid is in there; the piston seals are nfg...replace the wheel cylinder.
