Chevrolet Colorado
Platform: GMT 350, GMT 31XX
temp gauge increase if i turn off
Old May 27th, 2013, 5:55 PM
isaac rm's Avatar
Default temp gauge increase if i turn off
hello,
well, i have read that is "normal" if temp gauge increase when the engine is turned off, but im not sure about that, i had a stat issue on my 07 colorado, P0128 code, so i removed the stat to test it and i saw a internal sealant damage, then i replaced it, the code is erased, but now the temp gauge increase almost 3/4 if i turn off the engine, a logic explanation is the cooling system stop it if i turn off the engine then temp increase but in order to be sure i had compared with the temp gauge on silverado which keep his position after i turn off the engine then decrease with time.
So i would like to listen your experience about that,
Old May 27th, 2013, 7:26 PM
does this happen at key off or engine off key in run?
Old May 28th, 2013, 9:51 AM
isaac rm's Avatar
it happens at engine off key in run
Old May 28th, 2013, 3:26 PM
like you have stated, you really need to compare vs. the same truck with the same engine option.
IMO if the truck is running between 80 -100 degrees Celcius there is no problem.
chevypower101
October 13th, 2011 7:55 PM
Mr. Vann
Silverado & Fullsize Pick-ups
November 25th, 2009 7:24 PM
Mauler
March 2nd, 2009 6:40 PM
wrxsubaruwrx
December 3rd, 2006 12:33 PM
Quick Reply: temp gauge increase if i turn off
