Equinox This SUV offers a smaller, sportier stance than the Trailblazer, all without compromising the SUV abilities.
Chevrolet Equinox
Platform: Theta
equinox starting
Old December 28th, 2017, 12:50 PM
Newly Registered
danwinkel's Avatar
Default equinox starting
Battery appears fine but after a remote start failed i cannot start the car. What can i do?
Old December 28th, 2017, 2:21 PM
ruley73's Avatar
What year is the vehicle and how did you determine the battery is fine? When you say you can't start the car, be more specific.
If​​​ the starter doesn't engage when attempting to start it manually, then your battery is probably bad. This of course is with the assumption that all connections are good. Most people don't realize that the starter requires two or three times more power than everything else combined, and subsequently assume the battery is fine when it is not.
You can get a jump start and drive somewhere to have the battery & alternator tested.
The starter could be bad, but that's far less likely than a bad battery.
