egr valve
egr valve
I'm looking for the part number for an EGR valve for my 2010 equinox. The ABS and Stabillok lights just started coming on a few days ago. The mileage is around 70,000. For some reason the part number doesn't come up in a search for the 2010 model.
Without knowing anything else, I'm thinking you most likely have a problem with one of the wheel speed sensors. Relplacing the corresponding wheel bearing/hub assembly would probably fix it if that were the case.
