1970 chev g20
Old December 22nd, 2014, 1:19 AM
beaterwithaheater's Avatar
Default 1970 chev g20
i have a 1970 chev g20 van i need a few parts that are hard to find. the rear gas tank is rusted out and so is the sending unit what will interchange? i also need a dash pad the old one was fine until someone broke into the van while i was in the hospital and used up all the propane for the stove and ripped the cheap aftermarket radio out of the dash,he/she couldn't have taken it out nicely i have looked all over and have not found one for under 500 bucks what would interchange? i got the van for 300 bucks because the p.o. overheated the engine. he had white smoke coming out of the tail pipe,he stopped at a gas station and all they did was remove the thermostat. the engine got hot enough to weld the exhaust to the cylinder heads and cracked the heads. so far i have changed the bearings and cylinder heads,and exhaust manifolds. i picked the heads and manifolds up in the wrecking yard and had to use thick intake gaskets to seal things up. i also changed the timing set and put an hei distributor in. i think i will take the heads off and get the right ones,i probably should change the camshaft to otherwise it will go bad
Old January 24th, 2018, 12:56 PM
New User
Awaiting E-mail Confirmation
pieceofchevy's Avatar
still nothing? is anyone out in computer land.
Old February 1st, 2018, 7:25 PM
jimmydriver's Avatar
salvage yards. Some have websites that list what vehicles they have.
LMC truck parts in Kansas city might have the dash pad or check JC Whitney.
berekhhnd
November 24th, 2016 3:07 PM
beaterwithaheater
December 22nd, 2014 1:34 AM
choppervon
11
May 23rd, 2014 3:21 AM
bentwrench
August 25th, 2011 5:52 PM
chevywolf
December 18th, 2006 3:03 PM
Quick Reply: 1970 chev g20
