2000 express van 1500 4.3liter
Old July 27th, 2013, 8:57 PM
Highball's Avatar
Default 2000 express van 1500 4.3liter
Problem when driving the abs light comes on .the trans shifts funny and the speedometer is very erratic ..replaced the speed sensor and still does this. jacked the rear off the ground and ran the van .light doesn't come on so I back probed the frt. sensors left frt. voltage was 4.21 right frt 7.60 so I replaced the left frt. wheel sensor and the light still comes on .....What gives here...Thanks
Old July 27th, 2013, 11:21 PM
canucklehead's Avatar
Can you check the codes?
Old July 28th, 2013, 8:58 AM
Highball's Avatar
When I check the codes with a scanner there's nothing stored in memory ..
Old July 30th, 2013, 9:29 PM
Highball's Avatar
I found the circuit board on the instrument panel having (3) 100.J ohm resistors burned will let you know when repaired...
cas15
December 19th, 2013 7:33 AM
ChaosComplex
May 17th, 2011 11:07 AM
Cobrakidd
December 7th, 2008 12:22 PM
ss_early
May 17th, 2008 2:18 PM
dablazerboy
February 13th, 2007 10:47 AM
Quick Reply: 2000 express van 1500 4.3liter
