86 G20 5.0L Oil pressure gage & unrelated unidentified sensore
Old Mar 4, 2013 | 6:51 PM
martuseich's Avatar
Default 86 G20 5.0L Oil pressure gage & unrelated unidentified sensore
Hey Guys. I'm Brad, a new member and I have a 1986 G20 Van, 5.0L.
Oil Pressure gage looks like it's not working. Needle doesn't budge from 0. However, I have plenty of oil, no significant leaks and no lifter or engine noise that would indicate a real loss of oil pressure. Here's what I've done / checked, etc.
replaced Oil sending unit
20A fuse for the gages tests good using ohm meter
Temp & voltage gages work properly
No longer any dummy lights when you 1st turn ignition to run
Any ideas? How do I test whether guage is working?
On a completely different matter. I have a sensor on the driver's side of the engine with a single lead attached with a spade connector. The sensor sits between and above the 1st and 2nd spark plug wires toward the front. I just broke off the connector tab. Anybody know what this sensor might be?
wgander
May 23, 2015 8:18 AM
Billy HC
Mar 30, 2014 12:25 PM
rcsilverado
Feb 6, 2011 9:49 AM
saabman
May 14, 2009 2:25 AM
techdiver33
May 1, 2008 7:50 PM
